Resource Hacker 5.2.8.448 Silent
Resource Hacker is a is a free resource editor for 32bit, 64bit Windows applications, such as .exe and .res files, extract them, replace icons and bitmaps, and more.
Although it's made for advanced PC users, the app contains intuitiveoptions that can be figured out even by novices.
Examine, edit and extract resources
Wrapped up in a user-friendly interface made from a common window with a neatly organized structure,
the app lets you open resource files and explore their folders, such as bitmaps, icons, icon groups, string tables, version information, and manifest.
It's also possible to use a basic search function, save resources to .bin or .res files, replace icons, cursors and bitmaps with something else,
import data from text templates or blank scripts, add binary resources, or insert external resource files.
Resource Hacker facilitates approachable tools for inspecting, editing and extracting resource files, can be handled with ease by anyone.
Just make sure to create backups before modifying resource files, particularly if they belong to Windows.
Silent installation
https://www.mediafire.com/file/mcg1zmha7ssp6ey/Resource+Hacker+5.2.8.448+Silent+Install.7z/file
https://mir.cr/GJVYZSIE
