March 8, 2025Mar 8 🌟 Overview of Notepad++Based on the powerful editing component Scintilla, Notepad Plus is written in C++ and uses pure Win32 API and STL, which ensures a higher execution speed and smaller program size.Notepad Plus is trying to reduce the world's carbon dioxide emissions by optimizing as many routines as possible without losing user-friendliness. The PC can throttle down and reduce power consumption using less CPU power, resulting in a greener environment.🌟 Features of Notepad++✔Syntax Highlighting and Syntax Folding✔User Defined Syntax Highlighting and Folding✔PCRE (Perl Compatible Regular Expression) Search/Replace✔GUI entirely customizable: minimalist, tab with close button✔Document Map✔Auto-completion: Word completion, Function completion, and Function parameters hint✔Multi-Document (Tab interface)✔Multi-View✔WYSIWYG (Printing)✔Zoom in and zoom out✔Multi-Language environment supported✔Bookmark✔Macro recording and playback✔Launch with different arguments🌟 System Requirements✔Supported OS: Windows 11, Windows 10, Windows 8.1, Windows 7✔RAM (Memory): 2 GB RAM (4 GB recommended)✔Free Hard Disk Space: 200 MB or more Silent installation https://www.mediafire.com/file/f17kmj7d2qcofcb/Notepad++8.9.2+AIO+Silent+Install.7z/file https://transfer.it/t/eQSmwzwFADya Edited 3 hours ago3 hr by T3rM1nat0Rr3
April 5, 2025Apr 5 Author Changes in Version 8.7.9:Fix incorrect syntax highlighting regressions.Update to Scintilla 5.5.5 & Lexilla 5.4.3.Fix bug where plugin button hiding settings in toolbarButtonsConf.xml are ignored.Fix SQL Backslash Escape preference not taking effect immediately.Add new low-level DirectX11 DirectWrite 1.1 Scintilla rendering mode.Add versions of external libraries (Scintilla/Lexilla/Boost) to Debug Info.
May 12, 2025May 12 Author Changes in Version 8.8.1:Fix ShortcutMapper regression (from v8.7.6) of displaying wrong shortcut while editing.Fix Find in files progress bar visual regression (from v8.8).Fix search result cut off result content due to nul characters (‘\0’).Add Locale-based line sort feature.Enable selection history for undo & redo.Fix plugins removal failure issue (fixed in WinGUp).Fix tab settings for external lexers cannot be saved issue.Add ErrorList syntax highlighting.Fix disabled Paste command with no previous text-data in clipboard.Fix wrong directory opened for opening files issue.Improve Find dialog look & feel (more space).
July 2, 2025Jul 2 Author Notepad++ v8.8.2 release2025-06-30If your virus scanner reports malware in this release (a false positive), or you see the yellow UAC popup while installing this new version of Notepad++, don’t panic. It’s due to the absence of Windows code signing procedure. An explanation has been provided in the previous announcement.Although this release lacks a Windows code signing certificate, Notepad++ still provides a GPG signature. To protect against MITM attacks, use Gpg4win or Kleopatra, or at least verify the downloaded files using the puplished SHA256 fingerprint.The issue CVE-2025-49144 has been fixed in v8.8.2. This vulnerability affects only installer, but not Notepad++ itself. If you have already installed Notepad++, this issue does not concerne you. However, if you plan to install or update Notepad++, please use the installer from this release.There are more new enhancements and bug fixes.
July 10, 2025Jul 10 Author 2025-07-09“Sometimes, when one door closes (lack of code signing) in life, another one opens (vulnerability) .”The sentence sumarizes well the situation in the previous vession, 8.8.2.There were - and still are - many false-positives reported in the previous version v8.8.2, by the antivirus software due to the absence of Windows code siging certificate. To prevent this issue from recurring in future releases, from this version the Notepad++ release is signed with a certificate issued by a self-signed Certificate Authority (CA). The root certificate is published on the Notepad++ website, GitHub repository & Notepad++ User Manual, allowing antivirus vendors, IT teams and users to verify the authencity of each release.How to install the root certificate:Double-click the certificate, it may tell you it’s invalid, ignore that and click: “Install Certificate..”.In the Certificate Import Wizard, select “Local Machine”, then click Next.If promted by UAC (optional, depending on admin Previleges), click Yes.Choose “Place all certificates in the following store”, then browse and select “Trusted Root Certification Authorities”. Click Next.On the final page of the wizard, click Finish to complete the installation.For detailed instructions, see Notepad++ User Manual.We’re still trying to obtain a certificate issued by conventional Certificate Authorities, for a better user experience. But let’s be honest: it’s probably not happening. Notepad++ isn’t a business - it’s certainly not an enterprise - and apparently, that makes a popular open-source project invisible to their gatekeeping standards.If the “gatekeepers” won’t issue a certificate under the name we deserve - so be it. At least it spares us from wasting time and energy on a frustrting process that demands we beg for a new certificate every 3 years. The Notepad++ Root Certificate may not carry their approval, but it leads us to freedom.
August 14, 2025Aug 14 Author Changes in Version 8.8.5:Fix “Edit with Notepad++” context menu not being installed correctly regression.Changes in Version 8.8.4:Fix -notabbar & asNotepad.xml stop hiding tabbar regression (from v8.7.9).Fix “Edit with Notepad++” not removed by uninstaller regression (from v8.8.3).Fix possible heap memory leak.Increase search input length from 2046 to 16383.Add warning tip for the max length on search input (Find/Replace).Fix JavaScript listed twice in Language & Indent settings of Preferences issue.Fix external lexers showing several time in Indent settings issue.Add button to insert variables in the run dialog.Enhance “Go to settings”: guide users to the related setting explicitly.Add a clear button for filter field in Shortcut Mapper. Make NFO font overridable by adding font name in Lexer “nfo” of stylers.xml.
October 8, 2025Oct 8 Author Changes in Version 8.8.6:Add capacity of pasting multiline into Find/Replace fields.Improve UAC in app for seamless elevated operations.Fix Pin Tab operation being too long with many opened documents.Add 2 new full-readonly modes via command line argument (-fullReadOnly & -fullReadOnlySavingForbidden).Add apply/remove read-only for all documents commands.Column Editor enhancement: GUI input fields now support radix to match the output format.Add Window dialog “File Modified Time” sorting capacity.Fix NPPN_CMDLINEPLUGINMSG not working issue & define the pluginMessage usage protocol.Fix pasting from column mode to multi-selection issue due to different EOL.Add NPPM_GETNPPSETTINGSDIRPATH message to get Notepad++ settings directory path.Enhance SQL function list parser.Fix C# function list not working with comments.Add function list ability for CSS.Allow user to customize max selected chars to auto-fill “Find what” field.Restore undo/redo behaviour in Find/Replace fields after Copy/Paste or Ctrl-F.Fix text corruption issue caused by selection within multibyte characters.Fix DOCTYPE styling in xml and html.Fix double clicking on edit zone border creates a new tab issue.Update cURL in WinGUp (app updater) for fixing security issue CVE-2025-5399.
October 20, 2025Oct 20 Author Changes in Version 8.8.7:Sign Notepad++ binaries with GlobalSign certificat to fix false-positive alerts.Fix Monitoring in one view affects selections and position in second view.Fix Shortcut Mapper memory leak issue.Enhance Perl FunctionList for class.Fix pressing Alt or Tab causes controls redrawing problem in UDL dialog.
November 19, 2025Nov 19 Author Changes in Version 8.8.8:Add the app MSI (x64) for enterprise IT deployment.Security enhancement: Prevent the app updater from being hijacked.Fix multi-selection crash (regression) when smart highlighting is enabled.Add tab label length limitation option to have reasonable tab width.Improve the performance of saving session on exit.Fix Distraction free mode disabling tab bar hiding regression.Add text scale support.Fix switching among some encoding not working issue.Fix Notepad++ not handle system default code page UTF-8 well.Improve Rust handling: keywords and autoCompletion.
December 28, 2025Dec 28 Author Changes in Version 8.9:Remove Notepad++ self-singed certificate signature, use only the certificate issued by GlobalSign.Log security errors automatically while auto-updating in “%LOCALAPPDATA%\Notepad++\log\securityError.log”.Fix jarring color regression in dark mode (introduced in v8.8.9).Fix “/noUpdater” installer option not working if updater was previously installed.Fix column mode edit undo regression (introduced in v8.8.9).Fix issue where an empty file opened without encoding under a UTF-8 system codepage.Add makefile function list parser.Improve performance & add missing file ext. from langs.model.xml to langs.xml.Improve “Open containing folder in Explorer” command to avoid creating Explorer process.Allow refresh mouse scroll amount according to OS settings changes.
Friday at 07:11 PM3 days Author Notepad++ v8.9.1 release2026-01-26Several regressions were fixed in release 8.9.1: playback of macros that dulicated EOL, no matches found when pasting from Excel into the Find whatfield, and a regression in the customized context menu where the separator (id=“0”) escapes FolderName submenu.A long-standing bug was also fixed in this version: a single undo reverted multiple changes after macro execution.In addition to the fixed issues mentioned above, this release includes various bug-fixes & a few additional enhancements. You can view the full list of improvements for version 8.9.1 and download it here:
3 hours ago3 hr Author 2026-02-16“the XML returned by the update server is now signed (XMLDSig), and the certificate & signature verification will be enforced starting with upcoming v8.9.2, expected in about one month.“As promised in the announcement Notepad++ Hijacked by State-Sponsored Hackers, this release strengthens the weakest links in Notepad++ update process.Below is an illustration of how the Notepad++ update mechanism was previously hijacked:With security enhancements introduced in v8.8.9 & v8.9.2 (this version), this vulnerability is now fully addressed:As shown in the diagram above, 2 independent signature & certificate vérifications are now performed:Verification of the signed XML returned by notepad-plus-plus.org - implemented in this release (v8.9.2).Verification of the signed installer downloaded from github.com already implemented in v8.8.9.This “double lock” design makes the Notepad++ update process robust and effectively unexploitable.In addition to this major hardening, WinGUp (the auto-updater) has been also reinforced:Removed the libcurl.dll dependency to eliminate DLL side-loading risk.Removed 2 unsecured cURL SSL options: CURLSSLOPT_ALLOW_BEAST & CURLSSLOPT_NO_REVOKE.Restricted plugin management execution to program signed with the same certificate as WinGUp (i.e. only signed Notepad++).Of course, it’s always possible to exclude the auto-updater during the UI installation, or to deploy the MSI package using the following command:msiexec /i npp.8.9.2.Installer.x64.msi NOUPDATER=1
