March 12, 2025Mar 12 NET Desktop Runtime 8.0.25Microsoft .NET 8.0 is a free, cross-platform, open-source developer platform for building many different types of applications. With .NET, you can use multiple languages, editors, and libraries to build for web, mobile, desktop, games, and IoT.ProductiveIt helps you develop high quality applications faster. Modern language constructs like generics, Language Integrated Query (LINQ), and asynchronous programming make developers productive.Combined with the extensive class libraries, common APIs, multi-language support, and the powerful tooling provided by the Visual Studio family, Microsoft .NET is the most productive platform for developers.Any app, any platformWith .NET you can target any application type running on any platform. Developers can reuse skills and code across all of them in a familiar environment. From mobile applications running on iOS, Android and Windows, to Enterprise server applications running on Windows Server and Linux, or high-scale microservices running in the cloud, .NET provides a solution for you.LanguagesYou can write apps in C#, F#, or Visual Basic.C# is a simple, modern, object-oriented, and type-safe programming language.F# is a cross-platform, open-source, functional programming language. It also includes object-oriented and imperative programming.Visual Basic is an approachable language with a simple syntax for building type-safe, object-oriented apps.Cross PlatformWhether you’re working in C#, F#, or Visual Basic, your code will run natively on any compatible OS..NET Core is a cross-platform .NET implementation for websites, servers, and console apps on Windows, Linux, and macOS.Xamarin/Mono is a implementation for running apps on all the major mobile operating systems..NET Framework supports websites, services, desktop apps, and more on Windows.One consistent APIStandard is a base set of APIs that are common to all implementations.Each implementation can also expose additional APIs that are specific to the operating systems it runs on. For example, .NET Framework is a Windows-only .NET implementation that includes APIs for accessing the Windows Registry.Application modelsYou can build many types of apps. Some are cross-platform, and some target a specific OS or .NET implementation.Web. Build web apps and services for Windows, Linux, macOS, and Docker.Mobile.. Use a single codebase to build native mobile apps for iOS, Android, and Windows.Desktop. Create beautiful and compelling desktop apps for Windows and macOS.Microservices. Create independently deployable microservices that run on Docker containers.Game Development. Develop 2D and 3D games for the most popular desktops, phones, and consoles.Machine Learning. Add vision algorithms, speech processing, predictive models, and more to your apps.Cloud. Consume existing cloud services, or create and deploy your own.Internet of Things. Make IoT apps, with native support for the Raspberry Pi and other single-board computers.NET 8.0 supports Windows 10 1607 / Server 2012 or later, according t Microsoft .NET Desktop Runtime 8.0.25 Build 35812 x86/x64 Desatendido password <: ☛: 2026https://uploadcafe.com/Jd3p55Mxu9https://krakenfiles.com/view/oKCTXqnF9a/file.htmlhttps://pixeldrain.com/u/hvfCgWKq Edited 3 hours ago3 hr by T3rM1nat0Rr3
April 9, 2025Apr 9 Author 8.0.15 Latest release date April 8, 2025https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.15/8.0.15.md?WT.mc_id=dotnet-35129-website
May 14, 2025May 14 Author 8.0.16 Latest release date May 13, 2025https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.16/8.0.16.md?WT.mc_id=dotnet-35129-website
June 11, 2025Jun 11 Author 8.0.17 release date June 10, 2025https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.17/8.0.17.md?WT.mc_id=dotnet-35129-website
July 9, 2025Jul 9 Author 8.0.18 release date July 8, 2025https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.18/8.0.18.md?WT.mc_id=dotnet-35129-website
August 6, 2025Aug 6 Author 8.0.19Release notes Latest release date August 5, 2025https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.19/8.0.19.md?WT.mc_id=dotnet-35129-website
September 10, 2025Sep 10 Author 8.0.20Release notes Latest release date September 9, 2025https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.20/8.0.20.md?WT.mc_id=dotnet-35129-website
October 15, 2025Oct 15 Author 8.0.21 Release notes Latest release date October 14, 2025https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.21/8.0.21.md?WT.mc_id=dotnet-35129-website
November 12, 2025Nov 12 Author 8.0.22Release notes Latest release date November 11, 2025https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.22/8.0.22.md?WT.mc_id=dotnet-35129-website
January 14Jan 14 Author 8.0.23Release notes Latest release date January 13, 20268https://github.com/dotnet/core/blob/main/release-notes/8.0/8.0.23/8.0.23.md?WT.mc_id=dotnet-35129-website
February 11Feb 11 Author 8.0.24 Security patch Tooltip: This release contains fixes for security issues. If using an older patch release, you should upgrade to get these fixes.Release notes Latest release date February 10, 2026GitHubcore/release-notes/8.0/8.0.24/8.0.24.md at main · dotnet/....NET news, announcements, release notes, and more! - dotnet/core
3 hours ago3 hr Author 8.0.25 Security patch Tooltip: This release contains fixes for security issues. If using an older patch release, you should upgrade to get these fixes.Release notes Latest release date March 10, 2026GitHubcore/release-notes/8.0/8.0.25/8.0.25.md at main · dotnet/....NET news, announcements, release notes, and more! - dotnet/core
