PicView 3.1.2 x64 Multilingual Silent Free
PicView v3.1.2 :
PicView is a fast, free and fully customizable image viewer for Windows 10 and 11. It supports a vast range of image file types, including WEBP, GIF, SVG, PNG, JXL, HEIC, PSD and many others.Additional features includes viewing EXIF metadata, image compression, batch resizing, viewing images within archives and comic books, image effects, image galleries, and more.Enjoy a clean, free, and fast experience with no bloated UI or annoying pop-ups.Available in portable and installable versions.
PicView Concise Features:
  • Set image as wallpaper or lock screen image. (Image effect will be applied as well)
  • Basic editing: rotate, flip, crop, change the file type
  • Drag & drop/paste from clip holder support for files, folders, URLs, and archives
  • Scroll functiona
  • Open a file in an external application, show it in a folder, or view file properties
  • Color picker
PicView Details Features & screenshots:
https://github.com/Ruben2776/PicView
https://github.com/Ruben2776/PicView?tab=readme-ov-file#features-and-screenshots
PicView File supported:
https://picview.org/#FileSupport
Changelog v3.1.2 [May 03,2025]
  Hide contents
What's new
  • Added a new option to toggle between having background color option to fill the entire window or just behind the image. Enabled by default.
Improvements
  • PicView now remembers last used display monitor, when starting in full screen mode or maximized (#198).
Bug fixes
  • Set per monitor DPI to fix blurry images (#197).
  • Fixed the Image Aliasing option not rendering high quality mode.
  • Fixed a rendering issue when restoring from full screen while using auto-fit window.
  • Fixed some buttons not working in the Image info window.
  • Fixed the slideshow button not working correctly.
  • Fixed dragging and dropping an image locally viewed within the web-browser not loading.
Miscellaneous
  • Minor UI improvements.
  • Added Cancel button to exit the Image Resize window and the Batch Resize window.
  • Minor translation updates for Danish and English.
  • Fixed the Crop translation not appearing.
  • Updated to Avalonia 11.3.0.
OR
https://github.com/Ruben2776/PicView/releases
Silent installation
https://www.mediafire.com/file/6wktsck12p50ubj/PicView+3.1.2+x64+Silent+Install.7z/file
https://mir.cr/0ECSH9YE
Edited by T3rM1nat0Rr3
  • T3rM1nat0Rr3 changed the title to PicView 3.1.2 x64 Multilingual Silent Free
