Registry Finder 2.60 Silent I
Registry Finder is an improved replacement for the built-in Windows registry editor. It has many features that makes working with registry more productive, comfortable and safe, including:
  • Cut/Copy/Paste keys and/or values.
  • Undo and redo registry modifications (except changing permissions).
  • Multiple local and remote registry windows.
  • Fast, non blocking search.
  • Whole search results are displayed in a list.
  • Multiple search results window.
  • Ability to search within previous search results narrowing down your search scope.
  • Ability to search for hidden keys.
Registry Finder allows you to browse the local registry; create, delete, rename keys and values; modify values as its natural data type (string, multistring, DWORD) or as a binary data. It is allowed to open multiple Registry windows. Next time you start Registry Finder, those windows will be reopened on the same keys as before.
The Find operation is efficient and quick. All found items are displayed in a separate window as a list. Each line represents a single match with the search criteria. The icon shows where the match occurred: key name, value name or value data. Matched text is highlighted with red.
You can jump to any found item in the Registry window or edit/delete items right in the Find Results window.
Items in the Find Results window can be saved to file in .reg or .txt format. In latter case, items are separated by tabulator. It allows easy data importing and analyzing in other programs, such as Microsoft Excel.
With the Replace feature you can easily replace all or particular occurrences of one string with another. The replacement is performed only in items that are in the Find Results window. In the Replace dialog you specify either all items or just selected ones. After replacement is done, items in the window are updated. If some item do not match the search criteria any more it still remains in the list.
All operations that alter the registry including deletion and replacement can be undone and redone. The operations are listed in the History window. To open it, click View|History in the main menu. The last performed operation is marked with a yellow arrow.
Full name of the key can be copied to clipboard.
Dark theme
Registry Finder automatically uses dark theme when you turn on dark mode in Windows. (Head to Settings > Personalization > Colors. Select the "Dark" option under the "Choose your app mode" section.) Dark mode is available only in Windows 10 so, in turn, the dark theme in Registry Finder is available only in Windows 10. Screenshort of the main window in dark mode
Silent installation
https://seyarabata.com/6826207613a32
https://www.mediafire.com/file/bg4du4kawtt8781/Registry+Finder+2.60+Silent+Install.7z/file
الكاتب
