[req]auslogics system explorer
I have to recommend you pick up the Universal Silent Switch Finder (USSF) and read Ricktendo64's tutorial on Making a 7zip switchless installer You will find it's a lot easier than it seems. The command for your file was given with USSF in a second and a half. run:
"installer name /VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-" for a completely silent install.
Edited by thedexmonster
