Saving Task Bar Settings and Layout
Hi all,
Hopefully someone can help me here... How do I save my taskbar layout so when I nuke and pave it is restored to the way I like it? Which registry key(s) do I have to export?
Thanks!
Although not sure if this will work, you can give it a try at
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Streams\Desktop
and look for 'TaskbarWinXP' key
What I know is that it enables your Quick launch taskbar.
Thank you. Will give it a whirl.
