November 22, 2025Nov 22 Features Fully uninstall programs without leftovers Forced Uninstall removes any stubborn software Remove multiple programs at once Monitoring installation of programs Program quick search function Uninstall windows store apps Remove browsers' extensions Shred sensitive files Fix registry problems and boost your PC performance Remove junk files and unnecessary program files Delete invalid shortcuts in your system Find the empty folders in your hard drive Easily manage programs and services that start with Windows Easily manage windows system restore points Easy-to-use user interface Automatic update to the latest version System Optimization Tools (included): Process manager Startup manager Service manager Scheduler Task manager Context menu manager System restore manager Backup manager Shortcut manager and fixer Registry cleaner Junk files cleaner Empty folders cleaner File shredder Windows updates manager Windows Store Apps manager Browser extensions manager Program components manager HiBit Uninstaller 4.0.10 (2026-02-10)Added a File & Registry Finder tool.Added a Duplicate File Finder tool.Added a Disk Analyzer tool.Added Connection Manager tool.Added tree view for leftovers search results.Added support for custom folders in the Empty Folder Cleaner and Shortcuts Cleaner tools.Added a donation feature to support our work.Redesigned and added new features to the Process Manager tool.Improved the performance of Installation Monitoring.Improved the Windows Store Apps Manager performance.Improved the speed and accuracy of the Junk Files Cleaner tool.Improved the leftovers search algorithm, achieving 30% faster performance.Improved user interface.Fixed all known bugs. Homepage : https://hibitsoft.ir/Uninstaller.htmlChangelog : https://www.hibitsoft.ir/HiBitUninstaller/Changelog.txt Silent installation https://transfer.it/t/zpVBN8hxXDAA Edited 4 hours ago4 hr by T3rM1nat0Rr3
4 hours ago4 hr Author HiBit Uninstaller 4.0.10 (2026-02-10)Added a File & Registry Finder tool.Added a Duplicate File Finder tool.Added a Disk Analyzer tool.Added Connection Manager tool.Added tree view for leftovers search results.Added support for custom folders in the Empty Folder Cleaner and Shortcuts Cleaner tools.Added a donation feature to support our work.Redesigned and added new features to the Process Manager tool.Improved the performance of Installation Monitoring.Improved the Windows Store Apps Manager performance.Improved the speed and accuracy of the Junk Files Cleaner tool.Improved the leftovers search algorithm, achieving 30% faster performance.Improved user interface.Fixed all known bugs.
