[Request ] Where & When use "RegisterDLLs" + "RunPostSetupCommands" commands
I'm little bit confused :huh: and need your lightnings.
What is correct way :
============COMMON SECTIONS OF EACH INF FILE=================
[Version]
Signature="$Windows NT$"
[Optional Components]
EasyCapture
[beginInsPrompt]
Title ="::. %InsTitle% .::"
Prompt ="%InsQuest%"
ButtonType=YESNO
[EndInsPrompt]
Prompt="%EndInsPrompt%"
[Create.i386]
CMD /Q /C MD """%01%\i386""" & COPY /D /Y """%01%\*.cab""" """%01%\i386"""
[Delete.i386]
RUNDLL32 advpack.dll,DelNodeRunDLL32 %01%\i386,8
[sourceDisksNames.x86]
1="Easy Capture Setup Files","EzCpture.cab",,"i386"
[DestinationDirs]
EzCapture.CopyFiles =16422,EasyCapture
Stamps.CopyFiles =16422,"%STAMPS%"
Snapshots.Files =16389,"EasyCapture images"
PNF.File =17
DefaultDestDir =17
======================== INF 1 ================================
[DefaultInstall]
RegisterDLLs=Install.EzCapture
RegisterDLLs=Make.Dir
[install.EzCapture]
11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %01%\%THIS_FILE%,Install"
[install]
BeginPrompt =BeginInsPrompt
RunPreSetupCommands =Create.i386:1
AddReg =EzCapture.AddReg
CopyFiles =EzCapture.CopyFiles,Stamps.CopyFiles,@%THIS_FILE%
ProfileItems =EzCapture.Deskcut,EzCapture.Startcut,Remove.Startcut,Web.Startcut,EzCapture.url
RunPostSetupCommands =Delete.i386,EzCapture.iConnect
EndPrompt =EndInsPrompt
[Make.Dir]
11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %THIS_FILE%,SnapShots.Folder"
[snapShots.Folder]
RunPostSetupCommands=Create.Srnshot.Folder:1
[Create.Srnshot.Folder]
CMD /Q /C MD """%16389%\EasyCapture images"""
[EasyCapture]
OptionDesc ="EasyCapture"
Tip ="Powerful and easy-to-use free screen capture"
Modes =0,1,2,3
RegisterDLLs =Make.Dir
RunPostSetupCommands =EzCapture.iConnect
;----------------------------- END INF 1 -----------------------
**** FGCBA 0.897 log report ****
!- 3 error(s):
- Section [snapshots.Files] referenced in [DestinationDirs] does not exist in
EzCpture.inf!
- Section [DefaultDestDir] referenced in [DestinationDirs] does not exist in
EzCpture.inf!
- Invalid syntax in [Make.Dir] section:
(11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %THIS_FILE%,SnapShots.Folder")!
============================== INF 2 ============================
[DefaultInstall]
[install.EzCapture]
[install]
RunPostSetupCommands =Delete.i386,Create.Srnshot.Folder:1,EzCapture.iConnect
[EasyCapture]
Tip ="Powerful and easy-to-use free screen capture utility"
Modes =0,1,2,3
RunPostSetupCommands =Create.Srnshot.Folder:1,EzCapture.iConnect
----------------------------------- END INF 2---------------------------
!- 1 error(s):
- Section [DefaultDestDir] referenced in [DestinationDirs] does not exist in EzCpture.inf!
!- 1 error(s).
INF 1 & INF 2 seems to work fine, but I need to make it perfect.
Thanx for ur help. :icon_cool:
FGCBA_0.897_log_EzCpture_INF1.txt
FGCBA_0.897_log_EzCpture_INF2.txt
Edited by Ken@fri
FGCBA cannot handle that value. Just delete this line when you're running fgcba, then re-enable it in your inf.
DefaultDestDir =17 (required for real-time addon installing, not windows setup)
You've used Make.Dir section as a DLL register section. SO fgcba will look for dll syntax.
And this doesnt seem to be a dll register syntax:P
My idea (delete while fgcba check, then re-enable) will help you with this too. I dont know any other way to eliminate this.
- Section [Snapshots.Files] referenced in [DestinationDirs] does not exist in EzCpture.inf!
As fas as i can see you're really not using it anywhere. ?
@ bigfatroundguy
Thanx 4 your help. Link u gave was very usefull.
@ MrNxDmX
I've rechecked my INF, found all errors /mistakes & fixed it. Thanx.
