WInzard-PIW- Modular Post-Install Tool (Inspired by WPI)
Winzard-PIW
Inspired by the philosophy of WPI, Winzard-PIW is a modular post-install tool for Windows 10/11 designed to automate software deployment after a clean installation.
The goal is not to replace WPI, but to explore a modern structured workflow adapted to current Windows environments
Concept
PIW focuses on:
  • Local (offline) execution
  • Modular catalogue-based configuration
  • Clear separation between configuration and deployment
  • Transparent script-driven behavior
No installer redistribution.
No hidden background activity.
All actions are user-triggered and executed locally.
Architecture
The project is divided into two components:
PIW-Builder
  • Generates structured JSON catalogues
  • Handles silent switch detection (local analysis inspired by USSF logic, with optional metadata fallback when available)
  • Prepares reproducible configuration profiles
PIW-Deploy
  • Installs EXE / MSI applications
  • Deploys portable applications
  • Executes based on selected JSON profiles
This separation keeps the architecture clean and easier to maintain.
Current Status
Version: v1.5.1 Alpha
Recent improvements:
  • Complete Builder / Deploy separation
  • Improved silent detection pipeline
  • Removal of legacy wrappers
  • Cleaned folder structure
  • Fully English interface
A local stress test (29 applications) was completed successfully, validating the full workflow from detection to deployment.
Development Log
This topic will also serve as a development log for future updates.
Upcoming areas of exploration include:
  • Optional .reg support (user-controlled execution)
  • Installation priority management
  • Refinement of catalogue and profile handling
Long-term, a lightweight GUI layer may be developed (likely in Pascal/Delphi), acting above the existing .bat, .ps1 and .json structure without replacing the script-based core.
The main objective remains architectural clarity, modularity and user control.
Download
Latest Alpha available on SourceForge: https://sourceforge.net/projects/postinstallwizzard-piw/
Feedback from WPI users is welcome.
Edited by lokiju665
Project renamed for clarity.
  • lokiju665 changed the title to WInzard-PIW- Modular Post-Install Tool (Inspired by WPI)
