December 10, 200817 yr hello..can you make addon the program below download: http://voxel.dl.sourceforge.net/sourceforg...9.2Alpha8.2.zipwebsite: http://circledock.wikidot.com/ Edited December 10, 200817 yr by gogdos
December 10, 200817 yr Author WHOA THATS F*CKING COOL!!!ı know that is f"cking cool :naughty: can you make addon the program ??? :dribble:the settings that you made is in that "CircleDock0.9.2Alpha8.2\System\Settings" Edited December 10, 200817 yr by gogdos
December 10, 200817 yr well i`m working on it but i stopped for a while had some problem as the settings can't be changed to %programfiles%so i need to test updateins = command in inf i will try to release it soon
December 10, 200817 yr Author thanks you Dark MadnessKelsenellenelvian or ricktendo64 can you do this?
December 10, 200817 yr thanks you Dark MadnessKelsenellenelvian or ricktendo64 can you do this?well i can make one that is empty no icon or any added the problem is adding stuff to the docki will try to finish the empty one today and hope to upload it tomorrowEdit:I fixed an Issue i had with language Tomorrow i will start on shortcuts and uninstaller and test Setting hopefully the fix worksEdit2:All problems Should be Fixed now i almost finished the Rocket Problem i`m doing the latest Work in the inf then i would upload it Edited December 11, 200817 yr by DaRk MaDnEsS
December 12, 200817 yr Author well i can make one that is empty no icon or any added the problem is adding stuff to the docki will try to finish the empty one today and hope to upload it tomorrowEdit:I fixed an Issue i had with language Tomorrow i will start on shortcuts and uninstaller and test Setting hopefully the fix worksEdit2:All problems Should be Fixed now i almost finished the Rocket Problem i`m doing the latest Work in the inf then i would upload itok ı am waiting thanks :giveheart:
