help shortcut
hai, can help me to create shortcut to lanch inf file in start menu
and shortcut to automatic merge the registry file
sorry bad english :crying_anim02:
The trick to making shortcuts to files that dont have icons is to use IconPath and IconIndex to tell the shortcut what icon to use, if you dont the shortcut will not be created
Here is an example
Name=Shortcut Name
CmdLine=11,,"rundll32 advpack.dll,LaunchINFSection FileName.inf,InfSectionName"
WorkingDir=-1
IconPath=11,,shell32.dll
IconIndex=69; INF icon number
InfoTip=Registry tweaks
You can change the icon to whatever one you like, in my example I am using the number 69 which will add a shortcut with the icon for a INF file
Since this is a regtweak, here is another example using the icons from regedit.exe
Name=Shortcut Name
CmdLine=10,,"regedit.exe /s ""%11%\RegFileName.reg"""
WorkingDir=-1
IconPath=10,,regedit.exe
IconIndex=1; REG_FILE icon number
thx Rick for reply me
this work :thumbsup_anim:
you the best :thumbsup_anim: :thumbsup_anim: :thumbsup_anim:
[Version]
signature="$Windows NT$"
[Optional Components]
WinKey
[DefaultInstall]
OptionDesc="Enable/Disable WinKey"
Tip ="Enable/Disable WinKey"
Modes =0,1,2,3
CopyFiles =win_on.files,win_off.files
ProfileItems=enable.addshortcut,disablee.addshortcut
[WinKey]
Modes =0,1,2,3
[sourceDisksNames.x86]
1="WinKeys","win.cab",,"i386"
[DestinationDirs]
win_on.files =11
win_off.files=11
[sourceDisksFiles]
win_on.inf=1
win_off.inf=1
[win_on.files]
win_on.inf
[win_off.files]
win_off.inf
[enable.addshortcut]
Name= WinKey on
CmdLine=11,,"rundll32 advpack.dll,LaunchINFSection win_on.inf,DefaultInstall"
WorkingDir=11
subdir=WinKey
InfoTip=Enable WinKey
[disablee.addshortcut]
Name= WinKey off
CmdLine=11,,"rundll32 advpack.dll,LaunchINFSection win_off.inf,DefaultInstall"
WorkingDir=11
subdir=WinKey
InfoTip=Disable WinKey
probem Cmdline were the inf file in Program Files
Edited by 1st
If you are launching the DefaultInstall section you dont have to add it to the advpack.dll switch, also you are forgetting the IconPath/Index
[Version]
WinKey
[DefaultInstall]
Modes =0,1,2,3
[WinKey]
Modes =0,1,2,3
[SourceDisksNames.x86]
[DestinationDirs]
win_on.files =11
win_off.files=11
[SourceDisksFiles]
win_on.inf=1
win_off.inf=1
[win_on.files]
win_on.inf
[win_off.files]
win_off.inf
Name= WinKey on
CmdLine=11,,"rundll32 advpack.dll,LaunchINFSection %11%\win_on.inf"
WorkingDir=11
subdir=WinKey
IconPath=??
IconIndex=??
Name= WinKey off
CmdLine=11,,"rundll32 advpack.dll,LaunchINFSection %11%\win_off.inf"
WorkingDir=11
subdir=WinKey
IconPath=??
IconIndex=??
