Dexpot 1.4.1
Dexpot 1.4 turns your monitor into up to 20. It creates and manages virtual desktops and enables
you to work far more efficiently and comfortably with many simultaneously opened windows on
Windows 95/98/ME and NT4/2000/XP/2003/Vista (incl. x64).
Licence: Freeware
Release date: 05-oct-2008
Author of the program: www.dexpot.de
Add-On:
md5.png 2d56f56ed2ac4617bb3030fde2d59639
size.png 2.1 MB
Edited by zEn
Licence: Freeware
hey, thanks for this.
Hi thxx for the addon
First you need to fix the link
there is 2 extra // before the link that needed to be removed
second
you used auto it for making the addon you should have using the sielnt command and added /S and it would be silent
third
add the word addon to your program so it works with Rvm Intergator
i hope i helped
second
third
i hope i helped
1. I don't know why need to fix the link??
2. Yes I started with AutoIt, and i was to lazy to check it out for the silent switch, and just change the program from 1.4 to 1.4.1 version.
3. Sorry allready uploaded files but next time i will do that. :rolleyes:
Edited by zEn
2. Yes I started with AutoIt, and i was to lazy to check it out for the silent switch, and just change the program for 1.4 to 1.4.1 version.
see the link
http:////www.mediafire.com/?thmz1wzgawx
see the link
It looks better now, isnt it buddy ;)
Hi, I use this program a few months and I'm glad to have your addon. Thanks
thankyou nice tool zEn
