Installing XP Unattended from USB
Hi,
Can anyone tell me how can i install a nlited Windows XP SP3 from a 4GB USB Flash Drive?
I have found an article on MSFN but i am not sure is it the best way to install from USB drive. I don't want to run from USB drive. I only want to install from the USB drive.
Its to do with your BIOS.
You need to change the Boot Settings so that it boots of a USB Drive.
I'm not sure whats it called buts its there.
Just make sure you have it 1st boot then what ever you want after..
Hoped i helped. :)
Thanks snakecracker, but i already know that.
What i am asking is how to use the USB Drive to Install XP to the hard disk.
Just copying the files from the CD to USB doesn't work. I want to know the correct way to do it?
Right I just got this site from google.
It seems to be what your looking for:
http://www.ngine.de/article/id/8
Good Luck :)
Good Luck :)
Wow! :thumbsup_anim: That article is awesome but it is no what i was looking for.
In my last post i told you that i just want to use the USB drive to install XP to the hard disk. I don't want to install XP on the USB drive, just want to use it as a source for installing windows to the hard disk.
I actually found the How to install from USB- WinSetupFromUSB with GUI on MSFN.
But thanks for your help anyways cause i must agree that the article you gave me is awesome.
lol ok mate.
I was thinking of doing this as well.
Thanks for the link.
And its okay. I help as much as I can. :)
I know the answer was already given, but sometimes a video helps also. I came across this when looking for a way to do this on my Acer Aspire One, which doesn't come with an optical drive.
