July 5, 200916 yr Windows Post-Install Wizard (WPI for short) is a hypertext application designed for giving users choice. While Windows XP offers many ways of customizing the setup process out of the box, its major drawback is the lack of being able to select which applications an end user may install. In the past, end users and administrators needed to either download the files manually, or create overly complex scripts that could only be used once. WPI allows you to create one image, which can then be custom configured, and optionally, automated, so that end users can install any applications.WPI is a simple to use automation program for the choice and installation of multiple programs, tweaks and scripts. No longer will you need a dozen CD's or more when doing a fresh Installation. No longer will you need multiple files when you are servicing another PC. With Windows Post-Install Wizard all that you will need is 1 or 2 CD\DVD's to fully install your PC with all of your apps, scripts, registry files or tweaks. Instead of having to re-download those apps like adobe reader, flash or updates to programs you can have them all on one disk. With WPI you can have all of them all on one disk and then have a nice interface for selecting which apps to install and after configured properly WPI will install all of them without any needed input from you. WPI also and is commonly used added to your windows installation disks. This way you can automate the complete process of Windows and program installations.With your typical setup of WPI you have your OS and all of the apps, tweaks and such on one disk. After windows installs, WPI kicks in and you are given a selection of everything you have configured WPI with, then you can select the ones you want or simply let the timer run out and your default apps will install.Highlights of the newest version!v7.6.0 Updates - Released July 5th, 2009========================================================================* Updated the Manual.* Added License tab to About window.* Fixed a function name typo: had DriveAvailableSize(), but should havebeen DriveAvailableSpace().* Added function {JSCRIPT}=CreateShortcut() to Commands menu in ConfigWizard to create a shortcut.Usage: {JSCRIPT}=CreateShortcut("Description","IconLocation","Hotkey","TargetPath","Arguments","Destination","Folder")Description: Shortcut to MyTextFileIconLocation: C:\Windows\Notepad.exeHotKey: CTRL+SHIFT+FTargetPath: C:\Docs\MyTextFile.txt-or-TargetPath: [url="http://www.mywebsite.com"]http://www.mywebsite.com[/url]-or-TargetPath: \\server\files\ThisOne.xlsArguments: -c -q (command line arguments for a program)Destination: Desktop, Favorites, etc.Folder: Subfolder in MyDocuments, StartMenu, etc. Can be nested.Note: Use the wizard to make it, please!Note: Start Menu places it in the upper section of start menu. Start Menu\Programs places it in the main section of start menu.* Updated the error output when saving files.* Fixed a bug that would not gray a forced item. Would cause doubleinstallations in certain situations.* Fixed bug with WriteRegKey().* Added function {JSCRIPT}=setEnvVar().Usage: {JSCRIPT}=setEnvVar("USERNAME","Mark")Note: You don't need to specify the %'s.Why: Set environment variables for installation paths, users, etc.* Added function getEnvVar().Usage: getEnvVar("USERNAME")=="Mark"Returns: The value or if invalid the same name passed.Note: You don't need to specify the %'s.* Added Bulgarian language. Thank you belivakov.* Added option to dropdown box in Options -> General -> "Do MicrosoftOffice debugger check". It was always done at startup, but occasionallycaused problems. Only needed if installed Office and do not change thekeys before WPI is started.* Updated the external modules to the latest versions.* Changed the picture width and height drop-down boxes to string gadgetsto allow any size to be used.* The picture width and height are automatically filled in. Change ifyou wish to scale the picture up or down.* Updated the Language drop-down box to show the language flag and putthe text in the matching language.* Added Sounds Scheme tab to Options Wizard to play sounds at criticaltimes. Look in Windows\Media and WPI\Audio\SoundsScheme for samples.The red stop button is there in case you played a long sample and wantit stopped.* Removed option "Randomly select theme" from Options Wizard -> Style.* When change themes in the Options Wizard -> Style tab, the settingsare now loaded right away and can be changed. No more need to exit thewizard to load the new theme settings.Notes and ExtrasSuggested disk folder layout:With the above folder layout all your config entries should read like:["%wpipath%\Install\Blah.exe" /switch]Here is a small tutorial on how to add an app to WPI!Ok this is a sample (Very simple) configuration for CCleaner (A.K.A Crap Cleaner) This assumes you have all of the WPI files either in the WPI folder at the root of your Windows cd or all of the WPI folders (Common, Graphics, WPIScripts, Tools, Install and Themes) and the file WPI.hta at the root of your cd.Remember this is just the most basic and required entries for a program!1. Download the app and place it in the WPI\Install Folder. (CCleaner.exe in this example) 2. Run WPI.hta and click on the
