Posted September 26, 200916 yr The First version is out herewell i wanted to post about an upcoming tooli'm already working on it's the same as makecab but would be working with Vista and 7but i just wanted to remember as i didn't use MakeCab since a while well it works that way you choose a folder and it makes a cab for it that all i did until now i can make it when added a cab file it extract it so anything you want to add please tell me the tool still in a work stagehope the tool be out soonWhat have been Done So Far1-choose the Folder and the cab would make a cab for it2-choose a cab file and it would be extracted3-choose a file that not a cab compressed and it will compress it to cab (using makecab command)4-Choose multifiles and it will compress it (if you want to compress some files not a hole folder)Problems1-Cabbing And Extracting in the Drive is not possible(in C: or D: etc..)<<Vista and 7 UAC Problem( i added the Run As Administer to work in any place)2-Autoit compiler takes a lot of space (almost 300 kb)(something i can't fix sadly it how autoit compiles) Also What Icon should i make it for the program Edited September 27, 200916 yr by DaRk MaDnEsS
September 26, 200916 yr This is something I am interested in, I dont wan to to install TugZIP on win7 just to get a caber.
September 26, 200916 yr well same here i'm using cabarc it's that cab tool as i didn't get used to use dll files and i'm sure it would be needed other than TuGzip
September 26, 200916 yr I was making a Windows 7 Icon pack for XP and I made one especially for CabTool...too bad I dont have it in 128x128Maybe it will give you inspiration
September 26, 200916 yr I was making a Windows 7 Icon pack for XP and I made one especially for CabTool...too bad I dont have it in 128x128Maybe it will give you inspirationwell one thing i'm bad in is using Photo Shopi'm good at googling this icons i found it on the net if any one wants to make on it's ok and thx for that one Ricks it looks coolEdit: i think it doesn't matter the size it would only be the icon in the SendTo i wouldn't make an out shortcut for it Edited September 27, 200916 yr by DaRk MaDnEsS
