October 15, 200916 yr Size : 13.9 MBCRC32 : A24088DAMD4 : 1BD03135C7E282763BA76D91FFEF6C0AMD5 : 2EF9F23CD10B4BD3CC9CE9F864327975SHA-1 : F42B2743835F0BBB78BBB04F5E25BBB5D8442E6AProgDVB is a software which allows you to watch SAT-Television and listen to Radio channels directly from satellite by using DVB-PCI cards with hardware decoders on the board, SAT-dish, and personal x86-compatible computers.ProgDVB is a very useful application for those who want to watch television shows and programs on their computer.ProgDVB has options for working with network broadcasting and Audio/Video recording of the stream to different digital-media formats. ProgDVBR is in development, so new versions will be available for download from time to time.At the present moment work on the following cards is possible:Aver DVB-SBroadLogic 2030/1030Compro VideoMate DVB-SDVBWorld USB2.0 DVB-S/DVBWorldDTV(PCI-Sat), Acorp TV878DS/ DS110/ DS120, Nextorm NBS240/ NSC120GeniaTech DigiStar DVB-S PCIKworld DVB-S 100 compatible (Vstream, Dynavision..... )ADS Tech - Instant TV DVB-S (Part Number: PTV-341)LifeView FlyDVBNetcast DVBNEWMI Advanced DVBPinnacle PCTV Sat (driver >=260)Nexus,Premium (SkyStar1) (the driver 2.x from TechnoTrend)TBS Q-BoxTechnisat Sky Star 2 and Sky Star 3 USB or PCITelemann Skymedia 300 DVB (not official)TwinHan compatible (VisionDTV, Power Color, Chaintech,...)WinTV NOVA (Budget) USB or PCISt@rKey usb boxCards with BDA driver (With some cards problems are possible)Besides work in absence of a card is possible, for example for viewing video of files or as the broadcast client.PREREQUISITE : .NET Framework 2.0Publisher : ProgLicense : FreeVersion : 6.84.3 StandardOS : 2000/XPLanguage(s): English, FrenchNOTE: (TO SKYSTAR1 USERS/BELONGERS) Before starting the ProgDVB software - make sure you have SkyStar1 properly installed. It will be better to use IRQ11 or 12 (not shared with others devices). And in the Network's Option of your PC - Virtual Adapter need to be also configured with TCP/IP. Of course it is more better to use the new drivers from Techno Trend 2.09 or 2.10.Requirements:Intel Pentium - III Processor 500 Mhz.128 MB memory on board.5 MB of disc space (without size of disc space for Video&Audio Recording).AGP SVGA GraficVideo-Adapter with 32 MB memory on board.SoundBlaster compatible sound cardNetwork adapter 10/100 MB/Sec. (High speed Net-card is strongly recommended for Broadcasting).DirectX v.8.0 or higher.It is much better to use the new drivers from Techno Trend v2.09 or 2.10.For work with Recording's option you will need to install some software codecs from different manufactures.Addon default settingsAll settings are stored in the root folder of ProgDVB (ProgDVB.ini file)NONE source of TV selectedEnglish is default languageDefault skinProgDVBService :enabled per default (but you can disable it though ProgDVB Start menu group)TimeShift File (Timeshift.dat) is stored in the root folder of ProgDVB (Buffer size = 200 MB)Remote Control type : NONE or other typeCOMPONENTSProgMedia Server Module : Stream channels to other PC(s) in networkInternet Gate : Access to channels from other PC(s) over InternetPID Recorder Module : Recording data from transport stream deviceElecard MPEG-2 codecs - 21 days free trial : MPEG-2 (ISO/IEC 13818-2) and MPEG-1 (ISO/IEC 11172-2) decodingThis addon is installable/uninstallable with Add/Remove Windows components Edited May 11, 201213 yr by Ken@fri
October 15, 200916 yr Author I also made a AIO Media Center Addons Pack called UltimateHTPC, available in Wincert French Forum.My UltimateHTPC addon contains followings apps :EventGhost (ENU/FRA)GOMPlayer (ENU)ProgDVB6 STD (ENU/FRA)VideoLAN (ENU/FRA)
May 12, 201015 yr Author Updated :- ProgDVB v6.49.4- Xtr3mAddOnRes.dll (v1.0.0.18) Edited November 18, 201015 yr by Ken@fri
December 5, 201015 yr Author Updated :- ProgDVB v6.49.8- Xtr3mAddOnRes.dll (v2.0.0.1)- Xtremres.inf (v1.1.1)
February 14, 201114 yr Author 14.02.2011UPDATEDProgDVB (v6.60)Fixed/Replaced[DefaultUninstall]RegisterDlls =Install.ProgDVB[install.ProgDVB]11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %01%\ProgDVB6.inf,Install"with[DefaultInstall]RegisterDlls =Install.ProgDVB[install.ProgDVB]11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %01%\ProgDVB6.inf,Install" to launch manual install (Right click --- > Install command in context menu)v6.60 will be online in few hours.
February 16, 201114 yr Author Fixed typo errors in INF file (Install section) Edited February 24, 201114 yr by Ken@fri
August 9, 201114 yr Author Je t'en prie/U're welcome, eltunisie.Si tu parles français, tu peux aussi fouiller du coté du sous-forum dédié aux utilisateurs de cette langue.
December 27, 201114 yr Author Updated- ProgDVB (v6.81)- Xtr3mAddOnRes.dll (v2.0.0.8)- Minors fixes in INF file
