VMware Tools 8.1.3 build 203739
Integrate this into your windows disk and you wont have to install it after windows installs in your virtual machine. If you are not installing in a virtual setting it will not install.
I don't have a Windows 7 or 64 bit operating system to build or test on. Sorry.
Created 10/29/2009
Tested with nLite and VMware Workstation 7.0.0 build-203739 on a 32bit Windows XP system.
File Name: VMwareTools_8.1.3_b-203739.cab
MD5: D8931742AE363DAAEDACACD7B3E9F1AB
Links:
RapidShare
iFileIt
