Posted June 23, 201015 yr Hello everyone..I'm New in this area, so I just pass by requesting a little Help for all of you.Well... I would like to create an addon with a program named Vienna Dock 2.0That's is the Link.I have all the files in a folder, but i do not know how to create a .inf with installation script or something like that. And also i want that vienna dock start with Windows (I'm using windows xp) I hope you understand me.Please help. This will be a nice Addon.Or...To make it Easy!!I create a Silent Install of this program. But once is Installed do not start with windows.How can i Change that? I want that this program start with windows. (start up)Thanks to Eveyone. :welcome: Edited June 23, 201015 yr by Wanako1
June 25, 201015 yr Using autoit script to install (It is wizard-base installation), not fully silent but near. Done to your taste! Enjoy.(Desktop shortcut deleted. Program lnk to current user Startup folder only)ViennaDock2_addon.cabSize: 2.79 Mb (2,921,288 bytes)MD5: C5DE7FDE3CA234422238DA78136AC304Will host for 7 days only
June 26, 201015 yr Author Thanks man!!I will Try it.. :thumbsup_anim: Man .....This is really Good man, Doesn't Matter if this is not fully Silent for me!!The Important thing is: IS WORKING PERFECT.Check this Picture at Windows Start...THANKS A LOT Man.. :thumbsup_anim: Edited June 27, 201015 yr by Wanako1
June 29, 201015 yr Author Ohh one more thing!!I try it in a Windows XP Pro in Spanish, but doesn't work, this gives me an error, somtehing like missing dll.But in Windows XP in English is working Perfect. :welcome:
