Posted August 30, 201015 yr Dear Friends, Please tell me that how can i put .reg files in my new xp so that they will silently get added to the registry after the install.The reg files will enable run.control panel in my computer.I want to add only reg files and not programs.Plzz specify the proper way and help me.Waiting for ur replies. Edited August 30, 201015 yr by cool1234
August 31, 201015 yr Here is an addon with those tweaks you postedhttp://www.mediafire.com/?774p3cdn5eof9dr- Its easy to make, use reg2inf to convert the .reg file to .inf- Create a Entries_<whatever>.ini file with the following basic stuff[general]builddate=<date>description=<describe the addon>language=Multilanguagetitle=<addon name>version=<version>website=<optional>- Under that you create a section called [registry_addreg] (or delreg depending on what you want to do, more info here) and add the converted from reg2inf regtweaks[registry_addreg]HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{2559A1F0-21D7-11D4-BDAF-00C04F60B9F0}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{D20EA4E1-3957-11D2-A40B-0C5020524153}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{21EC2020-3AEA-1069-A2DD-08002B30309D}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{871C5380-42A0-1069-A2EA-08002B30309D}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{7007ACC7-3202-11D1-AAD2-00805FC1270E}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{2227A280-3AEA-1069-A2DE-08002B30309D}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{645FF040-5081-101B-9F08-00AA002F954E}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{2559A1F3-21D7-11D4-BDAF-00C04F60B9F0}",,0x10- Zip, rar, cab or 7z the Entries_<whatever>.ini file (make sure to NOT use the word "Entries" in the addon filename) and integrate itTo verify your tweaks have been added, after integration go to I386 and look/expand NLITE.IN_ and see if your tweaks are in there
August 31, 201015 yr Author Here is an addon with those tweaks you postedhttp://www.mediafire.com/?774p3cdn5eof9dr- Its easy to make, use reg2inf to convert the .reg file to .inf- Create a Entries_<whatever>.ini file with the following basic stuff[general]builddate=<date>description=<describe the addon>language=Multilanguagetitle=<addon name>version=<version>website=<optional>- Under that you create a section called [registry_addreg] (or delreg depending on what you want to do, more info here) and add the converted from reg2inf regtweaks[registry_addreg]HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{2559A1F0-21D7-11D4-BDAF-00C04F60B9F0}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{D20EA4E1-3957-11D2-A40B-0C5020524153}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{21EC2020-3AEA-1069-A2DD-08002B30309D}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{871C5380-42A0-1069-A2EA-08002B30309D}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{7007ACC7-3202-11D1-AAD2-00805FC1270E}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{2227A280-3AEA-1069-A2DE-08002B30309D}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{645FF040-5081-101B-9F08-00AA002F954E}",,0x10HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{2559A1F3-21D7-11D4-BDAF-00C04F60B9F0}",,0x10- Zip, rar, cab or 7z the Entries_<whatever>.ini file (make sure to NOT use the word "Entries" in the addon filename) and integrate itTo verify your tweaks have been added, after integration go to I386 and look/expand NLITE.IN_ and see if your tweaks are in thereA million thanks to u bro.M speechless for ur help.
