DiffMerge is an application to visually compare and merge files and folders on Windows, Mac OS X, and Linux.
• Diff: Graphically shows the changes between two files. Includes intra-line highlighting and full support for editing.
• Merge: Graphically shows the changes between 3 files. Allows automatic merging (when safe to do so) and full control over editing the resulting file.
• Folder Diff: Performs a side-by-side comparison of 2 folders, showing which files are only present in one file or the other,
as well as file pairs which are identical, equivalent or different.
• Windows Explorer/Shell Integration: Right-click on any two files or folders in Windows Explorer to diff them immediately.
• Configurable: Rulesets and options provide for customized appearance and behavior.
• International: DiffMerge is a UNICODE-based application and can import files in a wide range of character encodings.
• Cross-platform: Identical feature set on Windows, Mac OS X, and Linux.
DiffMerge_3.3.2_ENU_inf_addon.cab
Size: 5.81 Mb (6,091,104 bytes)
MD5: 8EEC5373A5ABFC5E6A3A08C7ED8C4B9F
(Note: This addon is ENU only)
