What is WPI?
Windows Post-Install Wizard (WPI for short) is a hypertext application designed for giving users choice. While Windows XP offers many ways of customizing the setup process out of the box, its major drawback is the lack of being able to select which applications an end user may install. In the past, end users and administrators needed to either download the files manually, or create overly complex scripts that could only be used once. WPI allows you to create one image, which can then be custom configured, and optionally, automated, so that end users can install any applications.
The main interface which allows for selection of actions and installations to perform.
The configuration section where you add in all of the programs entries and commands.
The options screen. (WPI has become very user friendly and has many options now)
WPI is considered open source and will always remain free and never include any adware or simaliar crap.
