Change IP Configuration via VB Script
Option Explicit
Dim NetworkAdapter, AdapterConfiguration 'Objects
Dim IPAddress, SubnetMask, Gateway, DNS 'String Arrays
Dim RetVal 'Integers
For Each NetworkAdapter In
GetObject("winmgmts:").InstancesOf("Win32_NetworkAdapter")
If NetworkAdapter.AdapterType = "Ethernet 802.3" Then
For Each AdapterConfiguration In GetObject("winmgmts:").InstancesOf("Win32_NetworkAdapterConfiguration")
If UCase(AdapterConfiguration.ServiceName) = UCase(NetworkAdapter.ServiceName) Then
IPAddress = Array("192.168.0.10")
SubnetMask = Array("255.255.255.0")
Gateway = Array("192.168.0.1")
DNS = Array("35.8.2.41")
RetVal = AdapterConfiguration.EnableStatic(IPAddress, SubnetMask)
If Not RetVal = 0 Then
WScript.Echo "Failure assigning IP/Subnetmask."
End If
RetVal = AdapterConfiguration.SetGateways(Gateway)
WScript.Echo "Failure assigning Gateway."
End If
RetVal = AdapterConfiguration.SetDnsServerSearchOrder(DNS)
WScript.Echo "Failure assinging DNS search order."
End If
End If
Next
End If
Next
