Visual Subst - virtual drives in effect
I've found this great free app on the net. Probably someone will make an addon from this :)
Visual Subst is a small tool that allows you to associate the most accessed directories with virtual drives. It uses the same API similar to the console 'subst' utility, but makes it easier to create and remove virtual drives in a GUI way.
Personally, I use virtual drives everywhere
nice find :D
thanks
Thanks N1K
Edit: Here is the link of the Add-on:
Visual Subst Add-On
Edited by DennyMK
Thanks for sharing N1K Nice find
