[AddOn] Glary Utilities v2.8.0.366
Glary Utilities
Glary Utilities offers numerous powerful and easy-to-use system tools and utilities to fix, speed up, maintain and protect your PC.
*Optimize, clean and boost the speed of your Windows.
*Protect your privacy and security.
*Block spyware, trojans, adware, etc.
*Fix certain application errors.
*Simple, fast and User friendly interface
*For only private use
It allows you to clean common system junk files, as well as invalid registry entries and Internet traces. You can manage and delete browser add-ons, analyze disk space usage and find duplicate files. You can also view and manage installed shell extensions, encrypt your files from unauthorized access and use, split large files into smaller manageable files and then rejoin them. Furthermore, Glary Utilities includes the options to optimize memory, find, fix, or remove broken Windows shortcuts, manage the programs that start at Windows startup and uninstall software. Other features include secure file deletion, an Empty Folder finder and more.
All Glary Utilities tools can be accessed through an eye-pleasing and totally simplistic interface.
size.png@4.99 MB
md5.png 99DC6DFBD413E4DE3EB830495DECAAC2
Note: Shortcut (destination directory) can be found under Utilities. Shell extensions are enabled. AddOn is fully uninstallable.
