January 31, 200917 yr This add-on contains the settings I use to tweak Internet Explorer 7 for my use, which I found under RegTweaks Collection v0.4. It also installs the Internet Explorer 5 Web Accessories onto the system. In addition, it adds the Domain Block List to block some pornographic domains. It can installed without integrating into XP source.IE Tweaks in General:- Adds Government and Military to auto url searches- Keeps Dial-Up Connection active during user-switch- Disallow spying by web-sites by putting "about:" sites in Restricted- Changes default search engine to Yahoo- Adds MSKB, AV, GGL, MSN and FM search keywords to IE.- Disable FTP folder view and use passive FTP- Disable download complete notification and allow IE window reuse- Disallow spying by web-sites by putting "about:" sites in RestrictedIE7-specific Tweaks:- Remove IE7 First Run Dialogs and Tabs welcome- Force IE7 Menu Bar to be displayed above address bar- Phishing Filter enabled by default- Adds all supported search scopes for IE7 (Picture)- Changes default search scope to Yahoo and IE7 Start Page to Yahoo.- Changes IE7 Tabbed Browsing behavior.FileName: Doug_IETweak_AddOn_v1.0.rar Size: 62kbMD5: 81D5C224FE64AED0F9A8819C7773E07ANOTE: While I am certain that settings will be applied with IE7 integrated, I am not sure whether they will be if IE7 is installed after windows setup is complete. Just a word of warning....
July 6, 200917 yr Author link is broken..Link has been fixed!Can we have IE8 Tweaks Addons. Please.I'll look into it.
October 30, 201114 yr Author Refreshed first post and updated link. Sorry it took forever to update it!
November 3, 201114 yr While you're cleaning stuff up, the link for - RegTweaks Collection v0.4 - appears to be invalid.Cheers and Regards Edited November 3, 201114 yr by bphlpt
November 5, 201114 yr Author While you're cleaning stuff up, the link for - RegTweaks Collection v0.4 - appears to be invalid.I've updated the first post with the revised link! Thanks for reporting that!
