January 31, 200719 yr [All In One] Vista MiniPlayer & Aero/Longhorn Sidebars by ears1991 Updated June-24-2007MD5: A22BB0747BEFB5EF9778750842BD77D6Size: 2.89 MBWebsite: http://ears1991.deviantart.com/Note: Installs to Start>All Programs... 100% UninstallableChangelog:June-24-2007Added both sidebar into one addon, also added the vista aero miniplater and reshacked the icons
January 31, 200719 yr Lol it crashed when I closed it.This is happening to me with IE7 on Windows Vista sometimes..
January 31, 200719 yr Weird, I cant repro that bug, have you tried the original link at deviantart, do you still get the error with that?
February 1, 200718 yr mmm... this kind of player is already included into wmp11, you just need to select compact mode using the arrow in the down-right corner
February 1, 200718 yr Author mmm... this kind of player is already included into wmp11, you just need to select compact mode using the arrow in the down-right corner Yea but with this one you can get the Vista Aero Glass Look
June 28, 200718 yr umm i think thers a problem with this addon, the 3 exe's arent getting copyed to system32.edit;ithink i figured it out, lol ure exe name are not the same, ure inf file says ie:"Vista_MiniPlayer.exe"but ure siource file="VMPlayer.exe" Edited June 28, 200718 yr by bober
June 28, 200718 yr Author Did you actually integrate it or did you just right click on the inf and selected install?
June 28, 200718 yr i did both acctualy, i saw after a win install under vmware that the 3 shortcuts in the start menu were not working, i did a search and the 3 exe arent even copyed at all.so i cheked ure inf, and im prety sure the names arent good and i think ure misisng 1-2 entries fore the files to get copyed when integrated.edit:shouldint ure inf look something like this;[Version]Signature=$Windows NT$[Optional Components]ears1991[DefaultInstall]ProfileItems=VMPlayer.AddShortcut,Longhorn.AddShortcut,Clear.AddShortcutAddReg =Uninstall.AddReg[ears1991]OptionDesc ="Vista MiniPlayer, Longhorn and Clear Sidebars"Tip ="by Chris Kennedy ~ ears1991"Modes =0,1,2,3CopyFiles =Copy.MainProfileItems=VMPlayer.AddShortcut,Longhorn.AddShortcut,Clear.AddShortcutAddReg =Uninstall.AddReg[SourceDisksNames.x86]1="aerobar_VistaMiniPlayer","aerobar_VistaMiniPlayer.cab",,"i386"[DestinationDirs]Copy.Main = 11[SourceDisksFiles]Aero_Sidebar_Clear.exe =1Aero_Sidebar_Longhorn.exe =1Vista_MiniPlayer.exe =1[Copy.Main]Aero_Sidebar_Clear.exeAero_Sidebar_Longhorn.exe Vista_MiniPlayer.exe[VMPlayer.AddShortcut]Name =Vista MiniPlayerCmdLine =11,,Vista_MiniPlayer.exeWorkingDir=11InfoTip =Aero Glass Windows Media Player.[Clear.AddShortcut]Name =Aero Sidebar ClearCmdLine =11,,Aero_Sidebar_Clear.exeWorkingDir=11InfoTip =Aero Windows Sidebar.[Longhorn.AddShortcut]Name =Aero Sidebar LonghornCmdLine =11,,Aero_Sidebar_Longhorn.exeWorkingDir=11InfoTip =Longhorn Windows Sidebar.[Uninstall.AddReg]HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","Comments",0,"Portable Media Player & Sidebars Vista and Longhorn Style"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","DisplayName",0,"Vista Apps by ears1991"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","DisplayIcon",0,"%11%\Aero_Sidebar_Longhorn.exe"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","UninstallString",,"rundll32.exe advpack.dll,LaunchINFSection ears1991.inf,UnInstall"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","URLInfoAbout",0,"http://ears1991.deviantart.com/"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","URLUpdateInfo",0,"http://ears1991.deviantart.com/"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","DisplayVersion",0,"2.0"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","Publisher",0,"Chris Kennedy"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","NoModify",0x00010001,01,00,00,00HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Vista MiniPlayer","NoRepair",0x00010001,01,00,00,00[UnInstall]BeginPrompt =BeginUnInsPromptRunPreSetupCommands=Close.Apps:1EndPrompt =EndUnInsPromptDelFiles =sys32.FilesDelReg =Uninstall.AddRegProfileItems =VMPlayer.DelShortcut,Clear.DelShortcut,Longhorn.DelShortcut[BeginUnInsPrompt]Prompt =%UninsQuest%Title =%UninsTitle%ButtonType=YESNO[EndUnInsPrompt]Prompt=%UninsFinal%Title =%UninsTitle%[Close.Apps]TASKKILL /IM Vista_MiniPlayer.exe /IM Aero_Sidebar_Clear.exe /IM Aero_Sidebar_Longhorn.exe /F[VMPlayer.DelShortcut]Name=Vista MiniPlayer,0x00000002[Clear.DelShortcut]Name=Aero Sidebar Clear,0x00000002[Longhorn.DelShortcut]Name=Aero Sidebar Longhorn,0x00000002[Strings]UninsTitle="ricktendo64 Uninstaller"UninsQuest="Remove Vista Mini Player and Sidebars from your computer?"UninsFinal="Vista Mini Player and Sidebars were successfully removed from your computer."and of course ure 3 exe's are being cabed into a aerobar_VistaMiniPlayer.cab archive. im trying to understand whats happening,im not very good in inf so mayeb im completely wrong.lol i jsut rebooterd my vm ware and ure short cuts are ok, lol i have no idea why it wasint working b4, sorry about all the confusion. :s Edited June 28, 200718 yr by bober
June 28, 200718 yr Author My addon does not use the inf to copy the files to system32... It uses txtsetup.sif, look at the entries.ini. The inf is used only to add the shortcuts (also its used for uninstall)AeroSide.exe = 100,,,,,,,2,0,0,Aero_Sidebar_Clear.exeLongSide.exe = 100,,,,,,,2,0,0,Aero_Sidebar_Longhorn.exeVMPlayer.exe = 100,,,,,,,2,0,0,Vista_MiniPlayer.exeI just tested this addon again and nothing is wrong with itEDIT: That INF you posted above is not my INF file. No clue where you got it from or who the hell moddified it
June 28, 200718 yr yeah i know its not 100% urs,cause i was under the impression the files werent getting copyed so i tryed to modify it to work, but like i said,lol i jsut rebooterd my vm ware and ure short cuts are ok, lol i have no idea why it wasint working b4, sorry about all the confusion. :s Edited June 28, 200718 yr by bober
June 28, 200718 yr [All In One] Vista MiniPlayer & Aero/Longhorn Sidebars by ears1991 Updated June-24-2007MD5: A22BB0747BEFB5EF9778750842BD77D6Size: 2.89 MBWebsite: http://ears1991.deviantart.com/Note: Installs to Start>All Programs... 100% UninstallableChangelog:sadly enough, i like that sidebar a lot more than the ugly vista thing
