[Solved] KB943790 not compatible with 7 SP1 (v52 final)?
I get this error when trying to add also KB943790 x64 to the update list (aside other 380 x64 updates) in the latest v52 final.
''Not compatible with 7601: 'C:\WinToolkit\CInst_Windows6.1-KB943790-x64\Windows6.0-KB943790-x64.cab' ''.
I don't believe this to be true, as it's only a feature pack. Please investigate this one also, Lego. :)
LE: added also the report log for this error. :)
ddd.txt
Edited by RicaNeaga
Windows6.0 is vista :/ Also below it says '6.1.7600.16385' so it won't work with SP1.
http://support.microsoft.com/kb/943790 doesn't mention SP1.
<?xml version='1.0' encoding='utf-8' standalone='yes'?>
<?Copyright © Microsoft Corporation. All rights reserved.?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v3" copyright="Copyright © Microsoft Corporation. All Rights Reserved." description="Windows File Management API" displayName="000000" manifestVersion="1.0" supportInformation="http://support.microsoft.com">
<assemblyIdentity buildType="release" language="neutral" name="Microsoft-Windows-Fmapi-Package" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" version="6.1.7651.0"/>
<package identifier="KB943790" releaseType="Feature Pack">
<parent integrate="delegate">
<assemblyIdentity buildType="release" language="neutral" name="Microsoft-Windows-Foundation-Package" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" version="6.1.7600.16385"/>
</parent>
<update description="Windows File Management API" displayName="Windows File Management API" name="Windows File Management API">
<selectable disposition="staged">
<detectNone default="true"/>
</selectable>
<component>
<assemblyIdentity buildType="release" language="neutral" name="Microsoft-Windows-Fmapi-Deployment" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" version="6.1.7651.0" versionScope="nonSxS"/>
</component>
</update>
</package>
</assembly>
Hmmmm... I didn't verify at first if the KB943790 was really vista (6.0) only, I got ashamed when I saw you explanation, however I really don't have any KB943790 for vista on my hdd, only for 7 (6.1).
You can see attached a screenshot from Everything (a cool search tool).
However, Win Toolkit extracts that 6.0 version from the 6.1 .msu (???). I swear if I must that the .msu integrated is the 6.1 one from the C:\7lite\updates\x64 location, and I'm not in the renaming .msu's period. Twilight zone bug :D Please investigate.
post-25565-0-90218200-1344290370_thumb.p
I can make it a first run update, and moving it to the silent installer folder, no problem, if it's that weird. :)
New issue with the updates installer in AIO. I'm not going to make another thread since it's a related issue.
kb2615327 x64 (ultimate x64 sp1) gives a red bar (not integrating ok) in AIO, and it's a first. I don't remeber seeing this in one of the test builds of version 51. Currently I'm using the latest build .52 final.
Please look into this for build 53... maybe move by default KB943790 to the silent addons section or smth, and investigate the kb2615327 red bar issue.
I'd really like a working solution after build 53 is out, so also please look to the other thread with the silent installer .exe corruption. Thanks. :)
