[Bugs] Many issues with the a-i-o creator
Here are issues I found with the a-i-o creator:
It no longer auto renames images. i.e adding a "86" or a "64" at the end.
When editing a description is no longer shows the edited name during the intital install process. (I am attaching a xml for what I thought it did)
When editing name and description and canceling it throws a " '' name already exists error"
OK let me clarify a bit more...
Things USED to be that after you selected the 2 wims and if you did not change names the toolkit would automagically add x86 or x64 to the end of the name.
This no longer happens.
The xml I provided in the first post was one I manually and painstakingly made myself.
if you look at one made by the toolkit you see this:
NAME
Windows 7 HOMEBASIC x86
NAME
DESCRIPTION
Windows 7 HOMEBASIC
DESCRIPTION
FLAGS
HomeBasic
FLAGS
HARDLINKBYTES
3069177344
HARDLINKBYTES
DISPLAYNAME
Windows 7 Home Basic
DISPLAYNAME
DISPLAYDESCRIPTION
DISPLAYDESCRIPTION
Note dislplay name was not changed like it used to be.
