QuickTime Alternative 1.81
QuickTime Alternative will allow you to play QuickTime files (.mov, .qt, .3gp and other extensions) without having to install the official QuickTime Player. It also supports QuickTime content that is embedded in webpages.
Features of QuickTime Alternative 1.81 :
- Media Player Classic [version 6.4.9.0 rev 611]: this is a full-featured player which has internal decoding support for DVD, MPEG-2, MP3, MP2, AAC, AC3 and DTS. It also has internal support for opening Matroska and Ogg containers. Media Player Classic is also capable of playing QuickTime and RealMedia content if those codecs are installed.
- QuickTime Codecs [version 7.1.6.200]: required for playing QuickTime content.
- QuickTime DirectShow filter: allows you to play QuickTime content in all DirectShow enabled players.
Without this filter QuickTime content can only be played in Media Player Classic.
- QuickTime plugin for Internet Explorer: allows you to view QuickTime content that is embedded in a webpage. It is installed together with the QuickTime codecs.
- QuickTime plugin for Opera/Firefox/Mozilla/Netscape: allows you to view QuickTime content that is embedded in a webpage.
- Extra plugins for QuickTime: plugins for viewing some special formats that are sometimes used on webpages.
- CoreAVC: is an external filter for Media Player classic
- CoreAAC: is an AAC DirectShow filter decoder based on FAAD2.
Features of QuickTime Alternative Lite 1.81 :
- QuickTime plugin for Opera/Mozilla/Netscape
- DirectShow MOV parser
- DirectShow QuickTime decoder wrapper
- CoreAVC
- CoreAAC
The only difference between the regular and lite versions is that the lite version does not include Media Player Classic.
Works only on Windows 2000/XP/2003/XP64/Vista.
Download QuickTime Alternative 1.81
Download: QuickTime Alternative Lite 1.81
Homepage: www.codecguide.com
