November 6, 201213 yr Just a little question:what is doing this Option?Is this option selected as default on starting AIO?TNX, Thiersee Edited November 7, 201213 yr by Thiersee
November 7, 201213 yr This is option is for deleting all Silent Installers from your image. For example, if you have this option selected and start a session all your slient installers will be removed from the image upon completion of that one session . The option to delete silent installers will be automatically deselected (disabled) at the end of your session.The option is not selected by default. To return the AiO Integrator options to their default value, click the button to the left of the options window. Cheers! Edited November 7, 201213 yr by dotfusion
November 7, 201213 yr Author Thanks dotfusion!Suddenly I found this option in an .INI checked and I didn't know how and why.
