Hello, guys. I'm happy to be part of this great forum and i really hope to learn some new stuff. So i got a question... eh i think i got the answer but just to make sure. So i merge my 32x and 64x install.wim to a single file using the great program WinToolkit and everything is working fine. But if i use the 32x folder to put the new install.wim with the 32x and 64x image inside i can use the repair option only for 32x installs and if i want to repair a 64x install i get the error that I'm not using the correct install. I guess there is a difference between the 32x boot.wim and the 64x boot.wim. This problem is kinda annoying because i still need to have 2x CD's with the different builds just for the repair option and my wish is to have a AIO flash drive. So i want to ask is there any way to get around this problem? So i can still have the 32x and 64x installs in one install.wim and somehow to be able to repair both types of OS if needed. Thank you for your time :) .
