February 11, 201313 yr I suggest to add a new function inside WPI. Inside wmi.js (from line 348):function getKeyboardLayout(){ position="wmi.js"; whatfunc="getKeyboardLayout()"; try { objWMIService=GetObject("winmgmts:\\\\" + "." + "\\root\\CIMV2"); colItems=objWMIService.ExecQuery("SELECT * FROM Win32_OperatingSystem", "WQL", wbemFlagReturnImmediately | wbemFlagForwardOnly); enumItems=new Enumerator(colItems); objItem=enumItems.item(); KeyboardLayout=objItem.Locale; } catch(ex) { } return KeyboardLayout;} Inside core.js (replace):// %OSLANG% var LCID; CreateLocalArray(); try { objWMIService=GetObject("winmgmts:\\\\" + "." + "\\root\\CIMV2"); colItems=objWMIService.ExecQuery("SELECT * FROM Win32_OperatingSystem", "WQL", wbemFlagReturnImmediately | wbemFlagForwardOnly); enumItems=new Enumerator(colItems); objItem=enumItems.item(); LCID=objItem.Locale; for (var x=0; x<arrOSLang.length; x++) { if (arrOSLang[x].LCID==LCID) { oslang=arrOSLang[x].TLA; oslocale=arrOSLang[x].Locale; break; } } } catch(ex) { oslang="ENU"; oslocale="English - United States"; } // Environment variable for batch file setEnvVar("HDD",hdd,false); setEnvVar("CDDRV",cddrv,false); setEnvVar("WPIPATH",wpipath,false); setEnvVar("ROOT",root,false); setEnvVar("OSLANG",oslang,false); setEnvVar("OSLOCALE",oslocale,false);} And remove inside core.js:function DecToHex(d){ position="core.js"; whatfunc="DecToHex()"; var hD="0123456789abcdef"; var h=hD.substr(d&15,1); while(d>15) { d>>=4; h=hD.substr(d&15,1)+h; } return h;} Inside global.js// wmi.js var KeyboardLayout; Inside global_lang.jsvar lblKeyboardLayout=[]; Inside information.js (on line 119):MyComputerGrid.addRow(gId++,getText(lblKeyboardLayout)+','+getKeyboardLayout()+''); Inside lang_en.jslblKeyboardLayout[lang] = ['Keyboard Layout']; Tested and works fine for me! Image:https://skydrive.live.com/?lc=4108#cid=D178EA021B182B88&id=D178EA021B182B88%211515 Thanks to check if it's OK! Regards
