WIM Risgistry Key for Win Toolkit Silent Installers and Options
Silent installers that are executed by WinToolkitRunOnce can be found in HKLM > WIM_Software > WinToolKit. Love it! I go there sometimes to make make minor adjustments to my silent installers. but...
Where can I find within the loaded registry hive the Keys that control the 'Install automatically' switch from AIO > Installers?
Edited by dotfusion
great thanks ... So if I removed the | character in front it would have the same effect as the toggle switch In Win Toolkit AIO > Installers?
EDIT: Seems to be the case, just remove the pipe sybol seems to hold. Awesome!
Edited by dotfusion
