April 3, 201312 yr Hi i make all correct whit WinToolkit to create a usb and the install is ok,but no create the disk partition for reserved for the systemwhat i do bad,i not understand and when i want instal net 3.5 wrong install. My iso is AIO and only extract the install.wim with windows media center Saludos/regards
April 14, 201312 yr I noticed the reserved system space is different in size between windows 7 and 8. While it's ''only'' 100MB needed for windows 7 (and vista), for windows 8 that virtual partition needs to have 350MB. You make it when asked where to install windows during windows install process (first stage). You probably have the hdd formated from a windows 7 install, and you only have a 100MB reserved system space. You have to delete the first partition (C:) at that first step and re-create it - by doing so, that 350 MB will be created (you have to press ok when asked).
