[Solved] .cab extractor
Hi Lego!
Not been about for a bit but thought it was about time I updated my "base" image files.
Now, forgive me if I'm wrong but at the moment I can't find the .cab from .msu extract tool, to lighten the load.
Then again at the mo, I've had a few bevvies! If it's gone can you advise the best way. When you've a few 7-zip isn't too helpfu!!
G'luck to you Sir and keep up the excellent work.
Elmer.
P.S. Has your numbering system changed as I've just downloaded the newest direct from here and the one it replaced had a higher serial, or mark number.
