January 13, 201411 yr Is there a way to delay running WinToolkitRunOnce.exe? In my case it does it behind the "Setting up your Desktop" screen and when that is done I only catch a glimpse of the end of the program.I would like to be able to see what drivers get loaded. Thanx
January 14, 201411 yr Author Here is an idea:In the install.ini file, have an entry that says Delay=x (x being amount of seconds)Then use "ping -n x 127.0.0.1>nul" at start of WinToolkitRunOnce.exe to pause it for x seconds.Hopefully Windows setup then finishes it's own thing and WinToolkitRunOnce.exe will run more visible.
