January 19, 201411 yr Source: http://www.wincert.net/forum/topic/11785-solved-brokenzer0s-great-bugsuggestion-report/Okay, sorry again, Iv saw just it later, that every bug need a own post.But thanks a lot for explainations and ofcs - solving all that things.Here i try to move the requests in requests subforum.For the exceptions:Okay seems that all updates not for Win7Sp1, but why do WinKit not skip these instead of create exception ? (Yap may some of them was "express" cabs, example this one who "cast as folder" after install was done.)(Im still just wondering why win8 updates and other not compatible still in some Win7 UpdatePacks.. what a crap. <.<For future i think i never use more this german-community ****, just only good ones like WHD, RiceNeaga and other.) Greez
January 19, 201411 yr They are not exceptions, they are telling you why those updates did not integrate. Can you post a screen shot and a copy of the log again please.
January 19, 201411 yr Author Ahh okay.Yay, u can find in: http://www.wincert.net/forum/topic/11785-solved-brokenzer0s-great-bugsuggestion-report/Screenshots n error log in spoiler of 1-2 n 1-5. But idk if its still in 30.10, found in 30.7
January 19, 201411 yr Author The 1-2 error came in 1.4.30.5The 1-5 error, idk remember, the log says came in 1.4.30.8 I think never 1.4.30.9+Not testes yet, if if comes still in 1.4.30.10+
January 19, 201411 yr Author Hard to reproduce the errors, the specific files were: windows6.1-kb2603229-x64-express.cabwindows6.1-kb2786081-x64-express.cabwindows6.1-kb2882822-x64-express.cabwindows6.1-kb2882822-x86-express.cab Some of them found by KUC by testing installed in VM, some of these was retrieved by Update Retriever (1.4.30.5 & 1.4.30.8)Iv tested now with 1.4.30.11 and follow express cabs, retrieved by Update Retriever of same version, these: Windows6.1-KB2446710-x64-EXPRESS.cabwindows6.1-kb2862330-v2-x64-express.cabwindows6.1-kb2913431-x64-express.cabwindows6.1-kb2913602-x64-express.cab Update2:So, integrating finished: no error window came more. But, the updates marked as "unknow error detect" (red icon) while integrating progress.The "integrated"-tab list these updates then as "not present". BTW: The express are ~50KB sized, thats normal? Edited January 19, 201411 yr by BrokenZer0
