AIO-Integrator: A better order updates
1) Why wintoolkit tries integrate WMF3.0 updates first and then the WMF3.0? I can not change the order because the updates are in BASIC, and WMF3.0 is in Silent Install - SFX
2) wintoolkit could better manage updates when list them? For example, I add to the list of everything related to integration "AD LDS" and the program first tries to integrate the updates and then the AD LDS. So it is with the update to "RSAT". First, list the updates and then the "RSAT" (etc, etc ...). It is easy to accommodate, but happens with many upgrades and is annoying to be up and down updates.
3) Because sometimes it does not integrate some upgrade and sometimes if? It happens with KB2815860 (AD LDS) upgrade. Do not be integrated and moves to Silent Install - SFX
Thx!
I agree with this request.
For the while u can click on buttons left side to move an update one line under an other.
In latest version u can also set in options "retry integrate" (much thx lego), so can also the others integrate.
Greez
