March 30, 201412 yr WTK ignored proxy settings in IE`s “Internet Options” and try download updates directly from server. It`s a bug? Win Toolkit v1.4.37.20, Win7.
March 30, 201412 yr Try with v1.4.38.2 available through the "Latest Builds" link in Lego's sig.. Cheers and Regards
March 30, 201412 yr Have any previous versions worked for you? What are your proxy settings, and where did you expect it to download from? Cheers and Regards
April 1, 201412 yr Author The last time I used WTK was when it download updates from McRip server There was no problem with proxy.Now I check Windows Hotfix Downloader. It downloads updates via proxy with no problem. I set proxy through `Control panel` - `Internet Options` - `Connections` Tab. Each connection I controlled with firewall and monitor in proxy program.
