Reporting errors
I´m only reporting some errors....
Fix it please:
An error occurred whilst integrating an update!
Exception:
Microsoft Windows [Versi�n 6.3.9600]
© 2013 Microsoft Corporation. Todos los derechos reservados.
D:\Ricktendo 7 lite\WinToolKit>Set SEE_MASK_NOZONECHECKS=1
D:\Ricktendo 7 lite\WinToolKit>"C:\Windows\System32\Dism.exe"  /Image:"G:\WinToolkit_Mount" /Add-Package /PackagePath:"F:\Ricktendo 7 lite\WinToolKit\Updates\Windows8.1-x64\Baseline\Windows8.1-KB2919355-x64.msu" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /English
Deployment Image Servicing and Management tool
Version: 6.3.9600.17031
Image Version: 6.3.9600.16384
Processing 1 of 1 - F:\Ricktendo 7 lite\WinToolKit\Updates\Windows8.1-x64\Baseline\Windows8.1-KB2919355-x64.msu: An error occurred applying the Unattend.xml file from the .msu package.
For more information, review the log file.
 Error: 0x800f0823
Error: 0x800f0823
DISM failed. No operation was performed.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
D:\Ricktendo 7 lite\WinToolKit>exit
Exception:
 Error: 0x800f0823
Error: 0x800f0823
Exception:
 Error: 0x800f0823
Error: 0x800f0823
Exception:
 Error: 0x800f0823
Error: 0x800f0823
Exception:
D:\Ricktendo 7 lite\WinToolKit>"C:\Windows\System32\Dism.exe"  /Image:"G:\WinToolkit_Mount" /Add-Package /PackagePath:"F:\Ricktendo 7 lite\WinToolKit\Updates\Windows8.1-x64\Additional\CameraCodecPack\Windows8.1-KB2899189-x64.msu" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /English
Processing 1 of 1 - Adding package F:\Ricktendo 7 lite\WinToolKit\Updates\Windows8.1-x64\Additional\CameraCodecPack\Windows8.1-KB2899189-x64.msu
F:\Ricktendo 7 lite\WinToolKit\Updates\Windows8.1-x64\Additional\CameraCodecPack\Windows8.1-KB2899189-x64.msu: An error occurred applying the Unattend.xml file from the .msu package.
 Error: 0x80073701
Error: 14081
