personal group names in 'updates + languages'
i would like to have option of creating my own customized group names for my updates. this way it would easier to find the updates i don't want to apply to a certain windows image. much simpler than saving different presets for each scenario
Edited by Profess0r1011000
If you want more control over updates I suggest you use a tool like KUC, it can scan your online or offline images for what updates it needs to add and it also tells you which ones are superseded
i'll look into it :) seems to have alot more to offer in the terms of information, and looking at the pictures of the interface i guess there is some power to managing that information as well.
