[Solved] v1.4.38.10 RunOnce doesn't work
- The runonce feature still doesn't work. This upgrade didn't solved the problem...
The contents of the "WinToolkit_RunOnce_Log".
Version: 1.4.38.10
Description:
-----------------STARTING--------------
Version: 1.4.38.10
Description: IsSystem: True
IsAdministrator: True
Version: 1.4.38.10
Description: WriteValue:HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnce | !1WinToolkit=WinToolkitRunOnce.exe | String
Version: 1.4.38.10
Description: Running as system. Aborting...
I hope you can find a solution for this situation.
Good luck ;)
Bump
@ Camino
do you run the WinToolkiRunOnce as administrator?
Edit:
All the stuff that's placed into this section isn't executed at the end of the new installation of Win7. I still need them to install manually.
Do you run the Win-installation by an autounattend.xml and you have there an autologon as Administrator?
Edited by Thiersee
@ Camino
to do that, is needed to mount install.wim and search in Mounted image> windows\system32\WinToolkiRunOnce.exe and at TAB compatibility click Run as Administrator
Edited by © KEiGHT
I think I didn't expresse myself very clear...
With the runonce, I was talking about the "Silent Installs + SFX" feature under the advanced tab.
My mistake
I don't use an autounattend.xml so the autologon as admin isn't set
Some older version back, I don't know the build version anymore, it did work quite nice. Maybe I did use then this autounattend.xml but I never used the autologon as admin.
