Hey,
I have been successful intergrating language packs into vista 32bit no problems what so ever.
But now when i try to do this for vista 64bit, it instantly fails them retry moves them to silent installer.
I tried imagex but it gives me a bsod, bad_pool_header when unmounting :(.
Could you perhaps try to locate what is wrong ?
iso=en_windows_vista_sp2_x64_dvd_342267.iso
language-pack1:lp-nl-nl_5f53001bc973bf44a920ce3b43cb39835ebab820
language-pack2:lp-pl-pl_3aad3b26549d0493cc8f17ec7298d52382a85eb8
Original downloaded as .exe used exe2cab to make it a cab.
Been trying different things as vlite what simply gives bsod.. and even bat also bsod.
Edit:
After checking the dism log, finding nothing.. i noticed a 1 or 2gb file, and a few other pretty big files.
Located @ C:\Windows\Logs\DISM
After deleting them, it seems to be working. not sure yet, but at least its not failing them instantly. so will report back after this.
Perhaps clean that directory except dism.log up after unmounting while still mounted you will be unable to do so.
Edit2:
Result! got a green one!
Will take a hour or 2 for it to complete the 2 language packs into all 4 mounts.
But it is looking good.
So lego, is it possible to add a extra cleanup option to clean up the dism directory ?
Edited by ThuGie
