On Virtual Machines, it works; on USB, it does not.
Greetings.
When I test a Windows 7 x64 build customized with WinToolkit on a Virtual Machine, the Installer part works perfectly.
But when I copy that very same build on a USB Drive to test it live, the Installer does not work, it just go through the normal installation process.
Any ideas please?
Thank you.
Of course, WTK builds an installation system, NOT a live system to run from USB (or DVD)!
Regards, Thiersee
Edited by Thiersee
Regards, Thiersee
I'm sorry, I did not explained the situation correctly.
When I want to test the build on a USB Drive, I use "Windows 7 USB-DVD Download Tool", to prepare the USB Drive and make it bootable.
Nevertheless:
With WTK you build an installation medium, no matter if USB-drive or DVD, to install Windows on HDD or SSD, NOT an installed OS to test it live!
Windows 7 USB-DVD Download Tool prepares an USB-Stick (or DVD!) and makes it bootable to INSTALL Windows!
Edited by Thiersee
