AIO-Integrator: Appcrash... Annoying bug...
Hey Liam,
Description:
  Stopped working
Problem signature:
  Problem Event Name:                        APPCRASH
  Application Name:                             WinToolkit.exe
  Application Version:                           1.4.47.2
  Application Timestamp:                     53ef80fc
  Fault Module Name:                          KERNELBASE.dll
  Fault Module Version:                        6.3.9600.17055
  Fault Module Timestamp:                  532954fb
  Exception Code:                                  e053534f
  Exception Offset:                                0000000000005bf8
  OS Version:                                          6.3.9600.2.0.0.256.4
  Locale ID:                                             1031
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
Please fix.. :(
Newer test results its going on every update..
And something newer mystic crash-stuff: :(
I think also anything is wrong with my system by the way... but dunno what its...
Update:
Ah, it seems i found the problem.
After i remove manually the folder %system32%\Temp\WinToolKit it works fine now. :)
But iv still no idea whats causing this annoying trouble...
Edited by BrokenZer0
Yay, the second one exist same time as the other and probably caused by same reason, so i think its better to post here for extending the information.
The Appcrash results suddenly also by integrating other updates,not just by integration the Win8.1-german-language-pack like the first time.
Both screens/trouble no more exist since i remove manually the %system32%\Temp\WinToolKit folder, but why that, i have still no idea.
Mhhh you mean both screens results because i was also removing the temps on the same time?
Ah, maybe it can be the problem, maybe i used CCleaner on the same time, i don't know more.
