Mounting while adding drivers hangs a bit
Hey,
For the first time i am trying to add some drivers.
around 400.. never knew just usb, chipset and lan drivers would be so extreme.
Extracted the 7z and removed the maps Vista Win8 and Server as i dont think it needs those on a win7 system.
So doubt its the drivers i am adding.
But when i press Start mounting keeps at 0% i see that imagex is running not sure why imagex and not dism perhaps speed or what not sure.
But it stays like this for quite some time until it go's to mount like normal and then it go's on extracting the underscore files etc.
And as i do all 4 of a x64 wim file speed makes so much differents.
Quick question btw,
If i do intergrate video drivers etc, simply unpack all 7zip files for win7 x64 and add them,
Would this cause problems, and would the installed windows actually contain all those drivers or just the once it needs ?
