January 15, 201511 yr First let me say I love this tool and thank you to all involved in creating it. I updated an x64 install wim using a program, Simplix Pack Windows 7 Updater. My install wim was 3,804,312kb after compressing with an imagex command. I then used Wintoolkit and removed 4 languages, Windows Gadgets and all but 1 local pack. I then used the rebuild option and created an ISO in Wintoolkit. I again checked the install wim and it grew to 3,805,745kb. Why does it grow when removing compinents. Thanks
January 16, 201511 yr From what I understand, the way that Win Toolkit removes components doesn't actually remove them from the install source, it just prevents the "removed" components from being installed. So the install source does get any smaller, (though I don't know why it got bigger for you), but the installed OS is smaller. Cheers and Regards
January 16, 201511 yr From what I understand, the way that Win Toolkit removes components doesn't actually remove them from the install source, it just prevents the "removed" components from being installed. So the install source does get any smaller, (though I don't know why it got bigger for you), but the installed OS is smaller. Cheers and RegardsSo I can't understand that why its written 'components will be permanently removed and nothing can be restored', when they are just prevented from installing?! Edited January 16, 201511 yr by niTe_RiDeR_Pro
January 16, 201511 yr We'll have to let someone answer who uses component removal, since I don't. Cheers and Regards
