Some Settings from Autounattend.xml not been set
Hi
i am new here but am experienced when creating Autounattend.xml files.
i have found a few topics here and and have tried them all with no success
i have used both the wsim tool from microsoft and your toolkit with the same results and i am now at the stage of banging my head against a wall
the following settings will not stick
1. timezone: i have put in both specialize and oobe at the same time and individually in each section and also used the %TIMEZONE% which is suppose to pull the setting from my wds server and does not
2. user name and password. - keep been asked to put this in. - is there a way just to set it once so every reboot afterwards it looks for the username and password.
i only want this set to eliminate this step during the setup
i am attaching my xml file
Autounattend.xml
