Running Processes on a remote Computer
Dim objWMIService, objProcess, colProcess, fso, objFSO1, objFile, objFolder
Dim strComputer, strList, strWritePath, textFile, strFile, strDirectory, i
Const OPEN_FILE_FOR_WRITING = 2
strComputer = inputbox("Enter Computer Name Here.")
strFile = strComputer &".txt"
strWritePath = "\\SERVER\files\Scripts\" & strFile
strDirectory = "\\SERVER\files\Scripts\"
i = 0
Set objFSO1 = CreateObject("Scripting.FileSystemObject")
If objFSO1.FileExists("\\SERVER\files\Scripts\" & strFile) Then
Set objFolder = objFSO1.GetFile("\\SERVER\files\Scripts\" & strFile)
Else
Set objFile = objFSO1.CreateTextFile(strDirectory & strFile)
'Wscript.Echo "Just created " & objFolder & "\" & strFile
objFile = ""
End If
If strComputer > "" Then
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" _
& strComputer & "\root\cimv2")
Set fso = CreateObject("Scripting.FileSystemObject")
Set textFile = fso.OpenTextFile(strWritePath, OPEN_FILE_FOR_WRITING)
Set colProcess = objWMIService.ExecQuery _
("Select * from Win32_Process")
For Each objProcess in colProcess
strList = strList & i & " " & objProcess.Name & vbCrLf
i = i + 1
Next
textFile.WriteLine(strList)
Wscript.Echo strList
Wscript.Echo "Done..."
Else
End If
WScript.Quit
PLEASE MAKE SURE NO WORD WRAPPING IS HAPPENING IN YOUR NOTEPAD!!!
Make sure you replace \\SERVER\files\Scripts\ with your UNC server path which you want to log to.
*Make sure that you have write ability to the file path.
